I have a 01 2500 SB 4x4, i was hooking up a new brake control the other day and found that in the fuse box under the hood fuse #8 40amp was blown. I replaced the fuse and now when I turn the lights on they will not shut off. I can remove the fuse and everything works fine. the headlight switch has been replaced thinking that might be the problem but it still does it. I also removed the brake control and with a good fuse in the fuse box the lights won't shut off. Does anyone have any Ideas on what might be the problem?
