2nd Gen Non-Engine/Transmission part ID pls
Engine/Transmission (1994 - 1998) Idle question
Engine/Transmission (1998.5 - 2002) smarty / high idle kit
Looked under the truck today and noticed that a control rod, running from the bottom of the rear LH shock aprox 12" to ?? was hanging loose at the top end. Replaced it onto the bushing it came from but obviously needs replacement. Can someone id the part and let me know what its function is?
Thanks
Ron
Does it look like the attached?
6 52009939AA VALVE, Height Sensing Brake
7 52009943AA LINKAGE, Height Sensing
8 4137696AB BOLT, Axle Vent
9 52010082AA HOSE, Brake, Height Sensing Proportioning Valve
10 52009942AA LINKAGE, Height Sensing
11 6502696 NUT, Hex Flange Lock, M10x1. 5, Height Sensor Bracket Mounting
12 6502696 NUT, Hex Flange Lock, M10x1. 5, Height Sensor Bracket Mounting
13 6101695 NUT, Hex Flange Lock, M8x1. 25, Height Sensing Proportioning Valve Bracket Attaching
Thanks for the pic. It is the rod #7 which dissconnected at the top end. I have put it back unto its bushing but the fit is very loose. What does this assembly do??
Brake porportioning valve. Controls the amount of pressure going to the rear brakes depending on the load in the bed.
