Part Name?
Can't have anything nice.
Front Hub Extension to Wheel Hub Fit Issue
I thought it was going to have an easy day finishing what I started a week ago. What is the front DRW extension called between that hub bearing and rotor? I can't find it on RockAuto. It looks like I need to buy a new one. When I did the first side, this was an easy operation. Spacer side right on and tighten up no problem. Today trying to get it on I used the nuts to try to get it to seat. No luck. It appears as though I tightened it so much I bent some of the lobes. Thanks, John.
One bad ball joint replacement. Turned into front axle u-joints, upper and lower ball joints and wheel hub bearing assemblies. Re-assembly of the first side went well. I thought today would be easy. Getting this extension on the wheel hub didn't go well.
All these threads you've started need to be combined back into one. No need for a new thread on the same job.
I asked in your other thread, are you sure the two hubs are the same? Same part number? Measure the same? Have you tried the other adapter on the other hub?
If you need a new adapter, as @Yo Hoot said, I'd find a used one. I don't imagine anyone will have a new one.
