Part #'s needed for gaskets
head liner
swiss cheese air box
Hey guys:
I'm changing out my stock housing (21cm) to a 12 cm wastegated housing in the near future. What all gaskets will I need and what are their Cummins part #'s? I also need the gasket that goes between the turbo and the wastegate on the 12 cm housing. So... . am I only needing 3 gaskets, 1 between the downpipe and turbine housing, 1 between the turbo and the turbine housing, and one for my wastegate. My Cummins dealer wasn't much help at all in the situation (They're not a B Series dealer) and the Local Dodge Stealer will get you the 2 gaskets in a kit for about $250, which is a complete turbo rebuild kit. Any help appreciated!
Thanks guys,
John
Can't help you with part numbers but remember to get the gasket for the oil return line from the turbo if you are going to be removing it to change the housing. I know that Cummins Northwest had no problem finding the parts for mine when I had a leak between the turbo and manifold. Your local Cummins dealer should be able to look it up, may need you CPL or serial number.
Good luck,
Caleb
I think there are only 3.
Oil inlet
Oil outlet
Turbo to manifold
No gasket between housing outlet and exhaust downpipe as I recall, just the V-Band clamp.
bob
Okay Joe. You've done outstanding so far buddy. I need one more part number QUICK, please. I've got to get these ordered tomorrow. The other gasket # I need is the metal gasket for the HX 35 wastegated turbo. It is the gasket that goes on the wastegate inspection cover. My local Cummins dealer hasn't been able to help me much so I need to rely on you guys. I have all of the other #'s wrote down but need this last one.
Thanks a million,
John
No need to sweat guys, I've found out that the gasket i was looking for was the turbo back plate gasket:) Thanks a lot for the help guys.
John
