after doing some serious testing and checking i've found a way to improve the around town power that doesnt require flooring it. under the diaphram there is a nylon stop. it looks like a thick washer. this stops the excentric from traveling down too far. i noticed my fuel pin wasn't traveling all the way up the taper so i wanted to see what would happen if it did.
so i shaved . 090" off it.
WOW!!!
part throttle power went way up. i checked with Northland diesel and they said it would not effect my max power settings so it should be safe and no, the pin will not travel too far. it can't by design.
i'm very happy with this little adjustment.
just thought i'd share
WOW!!!
