part #
Wheel Flares
BATTERIES...
Does anyone know the part #, for the transmission coolant return line that has a tap for a temp gauge.
Thanx in advance
Big A
I hope this is the current part number.
CH 05011244AA
Should be around $90. 00
Dave D
2001. 5 QC LB 4x4 Auto 3. 54 Everything but Leather Bright Silver Metalic ARE K Series Diprocal EGT, Boost and transmission Temp in an Autometer Dash Pod
Do we want the return line or the supply line to the cooler? Seems like the supply line is where you'd put the sensor.
If this is the part # for the supply line, and it will work on a '96 I might be interested in purchasing one before my guages get here.
Thanks,
Ryan
I read return and was thinking supply. The part number I had is for the supply line to the cooler, that would be the place to measure the fluid temp.
Dave D
AS far as I know,it's the line goin' back to the cooler. Kevin, I'll let you know if the dealer finds it.
Thanx
Big A
<font color=blue>BigA and K_Arts -
Why are you spending $90 on that part? All you need is a simple compression fitting to use. I can show you mine on the 14th. I'll even try to locate two of them for you.
