Got the oil pan off and out (with out pulling the transmission) so I could tighten the tone ring back into place. Found in the pan with one of the tone ring screws were two plastic tubes 1 3/16" long, 3/16" in diameter for 7/8" and then necked up to 1/4" diameter. It is hollow with about . 060" hole on the small end and . 125 on the large end. It shaped kind of like an insulated butt splice with one end cut off. I called Cummins to get the torque spec. for the tone ring screws (I'll Lock-tite them also) and asked a mechanic if he knew what they might be. He couldn't think of anything. I asked if they could be cooling nozzels (something I've never seen) but he said those are in the con rod and not plastic. Anyone know what they might be? I'd take a picture and post it but I don't have a camera yet. A new oil pan is ordered (damaged drain plug hole) and should be here Tuesday, so truck will be apart untill the weekend. I guess if no one has an answer by then, I won't worry about it. This truck is a 98. 5 24-vavle and not the one in my sig.
Kim
Kim
