Front end original lower ball joints ,uppers were replaced at 350,000kms. Original tie rod ends,one sector shaft replaced while still in warrenty loose from factory.
Always used Rotella 15/40 fleetguar filters. no oil use between changes at 6000k
Fuel system ,only change was moving the lift pump back by tank. standard fuel lines ,and banjo bolts. Presently on lift pump #4.
Despite all the warnings I have had a K&N air filter since new. there has never been any sign of oil in the turbo. When valves were checked everything was super clean. When the oil filters are cut open and examined there is no foreign matter that appears under a 10 power glass. Oil from the filter and engine sample put through a paint filter , never had any sign of anything abnormal. Use the same examination I use on aircraft ,works for me after 25 years.
I use mmo and Howes Meaner in every tank of fuel,filters are fleetguar and changed every 10,000 k.
regards to all fellow tdr members.
