Details here: TDR Privileges
the passenger side window will not roll down with the door switch (passenger side) but will work with the switch for the driver side. Is there a fuse for just the passenger side, or do you think it might be a faulty switch? Thanks for the idea's.
You didn't by chance have the window lock button on did you? Cause you can roll down all the windows from the drivers seat with the botton on but the passengers cannot roll it down. I'm sure that's not it but its just a thought.
We can all have that happen. I tried to log onto my online banking with each of 3 different accounts the other day and finally called the bank and asked them if their site was malfunctioning. He was SO nice about suggesting I check to see if I had my caps lock key on..... :-laf :-laf :-laf passwords being case sensitive... .
I'll bet it IS the lockout button. . cheap fix there !
I had that problem with my 96. It ended up being the window switch on the passenger door. the connectors eventually stop making contact. I used to pull the switch apart 3 - 4 times a year to crimp the barrels a little to make contact. Oo.
Same problem here on my '03. Intermittent problem with the drivers door switch not working the front passenger's window. And once out of a hundred, the passenger door window switch doesn't work. But 5 minutes later, all is well. AND no the window lock-out switch is pressed, even tried cycling the windows lockout switch to see if it was doing it.
Same thing happened to me a couple days ago. Was off roading with a group and my passenger said the window won't go down. The driver side switch worked fine. A couple bounces later, it worked again. Haven't looked in the door (or FSM), but maybe just a loose connector or something simple.
Same problem here, the right side passenger (front) window will not come up/down, next day will work, next day, not work!! go figure, have to wait until we head north to get it fixed.
