This is my 1st post to TDR. I have searched for days for the information that I need and seem to get more confused as time passes!!
My truck:
2000 2WD QC long-bed.
Camper special. (Overloads and stabilizer bar and what looks like a factory hitch. )
265 R75 16 Michelin tires came as an option
3. 55 limited slip rear-end
Auto trans
Previous owner installed BD ex. brake and a Torq-Loc plus Pyro and trans temp. , so it obvious that he towed a trailer. (No signs of a 5er hitch.
I expected to be able to haul an 8' to 8. 5' camper, since I had previously done so on and old 1/2 ton with additional springs and the only issue I had was with braking and fuel consumption. ( I had to stop often, <200 miles, and leave a respectable distance between me and any traffic. )
Here is the source of my confusion: The owner's manual speaks not at all about carrying a camper. The plate on door talks about MVGW of 8800# and also about so many pounds per axle with 245 R75 16 tires and wheels. According to the tires and wheels I have on the truck, I can carry 13660# at 80 psi cold! With the truck actual weight of 6760# (scaled at transfer stn) with two people and 1/2 tank of fuel, conservatively 500#, that leaves the empty truck at 6260#. I assume, therefore that the hitch, camper special parts, bedliner and B-D stuff accounts for the difference?? So my payload, according to the tires, would be 6800#. (Allowing 600# for 2 people and full tank of fuel)
BUT, nowhere can I find any adjustment for the camper special option or the larger tires. So what's the deal? The dealer copied a data sheet that implied a payload of 2740# and I assume that that is from empty weight, so if you subtract fuel, 250#, 2 people at 350#, that would leave just a little over 2100# for the camper and stuff.
Reliable sources, and this forum, have implied that cops etc. are concerned only about tire capacity. Does anyone know of a reliable source that I can feed the above data into and come up with an answer.
I never did weigh my old camper but it must be well over 2000# as I ended up with 1 ton springs on the old 318 and any hill pulled me down to 35-40 mph in 2nd. On the new truck it doesn't seem to know its there, but it does not fit well as the bed is narrower at the gate and I have to have a 6" spacer at the front of the bed to keep the camper from mangleing the sides at the latches.
My apologies for this being so long..... I was trying to define all the variables. Perhaps I am missing something very obvious.
Thanks for your time,
Ian
My truck:
Auto trans
Ian
