I have been spraying the various Nuts and bolts under my truck for days, in prep. for R&R exhaust and shocks. I finally, after great effort, managed to remove the exhaust flange bolts. Upon inspection, it was obvious that the area of the bolt threads that were in contact with the threaded flange... were as dry as a bone. No trace of "penetrating" oil.
Now, the 3/8ths inch of bolt that was protruding through the top of the flange, ok, maybe it helped the rust flake off of that so it would pass through the threaded section more readily, but as far as breaking up the rusty connection within the bolt/nut connection... my opinion, it is a waste of money.
I cranked on those bolts with a short cheater bar, to the point that I could feel my inguinal canals expanding, and that is when I came up with an idea.
I got my tack hammer out of the basement and had my wife use it to tap firmly on the flange while I tried to remove the bolt. It worked like magic! And no hernia!:-laf That trick won't be so practical on the shock bolts, since there isn't room for two people to work, but it certainly did on the exhaust flange.
