I am ordering the Auto Ingenuity product,
Here is a cut and paste from the Chrysler expansion module capabilities...
Enhanced Chrysler CAN-Based Module System Test List
NOTE: The list is for general module support for given module. Actual system test support is based on manufacturer discretion.
Anti-Lock Brake System CAN (Var. 07) top
Bleed Brakes
Anti-Lock Brake System CAN (Var. 08) top
Bleed Brakes
Audio Amplifier CAN (Var. 01) top
AMP Input Test
AMP Output Channel Test
Reset ECU
Auto Highbeam Module CAN (Var. 01) top
Aim Test
Cabin Compartment Node CAN (Var. 02) top
Auto Door Lock
Auto Door Unlock
Change Measurement Units
Language Preference
Seatbelt Alert Monitor
Unlock Driver Door On 1st Press
Cabin Compartment Node CAN (Var. 03) top
Auto Door Lock
Auto Door Unlock
CCN Gauge Test
CCN Self Test
Language Preference
Service Interval - Gas
Service Interval - Diesel
Cabin Compartment Node CAN (Var. 06) top
Self Test
Cabin Compartment Node CAN (Var. 09) top
Self Test
Climate Control - Manual CAN (Var. 03) top
Actuator Calibration Test
CoolDown Test
HVAC Self Test
Reset ECU
Climate Control - Manual CAN (Var. 05) top
CoolDown Test
HVAC Self Test
Climate Control - Manual CAN (Var. 11) top
CoolDown Test
HVAC Self Test
Driver Door Module CAN (Var. 03) top
Reset ECU
Driver Door Module CAN (Var. 05) top
Mirror Position Test
Reset ECU
Electronic Overhead Module CAN (Var. 01) top
EOM Self Test
Reset ECU
Electronic Shifter Module CAN (Var. 01) top
Reset ECU
Enhanced Powertrain CAN (Var. 01) top
EGR System Test
ETC Throttle Follower Test
Injector Kill System Test
NVLD Forced Monitor Test
Purge Vapors System Test
Reset ECU
Reset Memory
Set RPM Test - non - ETC Equipped
Enhanced Powertrain CAN (Var. 08) top
1st Gear Clutch Test
2nd Gear Clutch Test
3rd Gear Clutch Test
Clear Variable Line Pressure (VLP) Counters
EGR System Test
ESIM Forced Monitor Test
Quick Learn
Reset ECU
Reset Memory
Reverse Gear Clutch Test
Set Engine RPM System Test
Enhanced Powertrain CAN (Var. 22) top
Clear Learned Variable Line Pressure (VLP) Counters
EGR System Test
Injector Kill Test
Quick Learn
Reset Memory
Set Engine RPM
Final Drive Control Module CAN (Var. 01) top
Reset ECU
Front Control Module CAN (Var. 01) top
Program Tire Size
Hands Free Module CAN (Var. 01) top
HFM Self Test
Reset ECU
Heated Seat Module CAN (Var. 01) top
Reset ECU
Master Audio Unit - Radio CAN (Var. 01) top
Reset ECU
Master Audio Unit - Radio CAN (Var. 02) top
Reset ECU
Memory Seat Module CAN (Var. 01) top
Self Test
Standardization Routine
Parktronics Module CAN (Var. 01) top
Reset ECU
Sensor Functional Test
Sensor Wiring Test
Passenger Door Module CAN (Var. 03) top
Reset ECU
Passenger Door Module CAN (Var. 05) top
Reset ECU
Satellite Radio CAN (Var. 01) top
Reset ECU
SDAR to Radio Tone Test
Steering Column Module CAN (Var. 01) top
Reset ECU
Steering Column Module CAN (Var. 02) top
Reset ECU
Sunroof Module CAN (Var. 01) top
Reset ECU
Totally Integrated Power Module CAN (Var. 05) top
Accessory Delay Time
Actuate Engine Battery Feed
Actuate Transmission Relay
Auto Door Lock
Auto Door Unlock
Auto Wipers
Change Counter Code
Disable Radio Clock Display
Enable DRL
Flash Hazard Lamps On Lock
Headlamps Delay Time
Illuminated Entry Time
Program Network Configuration
Program Tire Size
Restore Vehicle Configuration
Sound Horn On Lock
Tip Start Temporary Disable
Unlock All Doors First Press
Update Radio market Select and DVD Region Code
View Last VTA Trigger Cause
View VTA Enable Data
Totally Integrated Power Module CAN (Var. 06) top
Auto Wipers
Change Country Code
Enable DRL
Flash Hazards Lamps On Lock
Horn Chirp Duration
Illuminatd Entry Time
Program Tire Size
Sound Horn on Lock
Update Pressure Thresholds
Update Radio Market Selection and DVD Region Code
Totally Integrated Power Module CAN (Var. 08) top
Actuation Transmission Relay
Auto Door Lock
Auto Door Unlock
Change Country Code
Enable/Disable DRL
Headlamps on with Wipers
Program Tire Size
Sound Horn on Lock
Unlock All Doors Firt Press
Update Radio Market Select and DVD Region Code
Transmission Control Module CAN (Var. 02) top
Reset ECU
Reset Learned Adaptives
Store Learned Adaptives
Wireless Control Module CAN (Var. 02) top
Program Left Front Tire Sensor ID
Program Left Rear Tire Sensor ID
Program Right Front Tire Sensor ID
Program Right Rear Tire Sensor ID
Program Spare Tire Sensor ID
TPM Trigger Module Test
Wireless Control Module CAN (Var. 03) top
Reset ECU
Wireless Control Module CAN (Var. 04) top
Antenna Loop Test
Reset ECU
Wireless Control Module CAN (Var. 05) top
I think it is gonna' rock!!!!
Mike.
