So my pcm took a dump and is not putting the ground to my ac clutch so I tied into the 85 terminal on the ac relay and ran a wire to the brown wire on the low side ac pressure switch. It works great now and cycles properly, but question is I just did a wire tap into the brown wire at the low pressure switch so it's still hooked to the switch and the pcm. Should I have cut the wire at the low pressure switch and ran the new ground to only the switch and left out pcm, or is it ok that it's tapped into the solid wire running from switch to pcm still? Truck is a 1995 2500 4x4 5speed extra cab. Can't find a good pcm as of yet and need this for temp fix
