2nd Gen Non-Engine/Transmission PCM/Cruise Control
Is there a reflash for the PCM that will reduce the sugring in Cruise Control mode. It is barely noticable in factory mode but any SMARTY mode agrivates it . On flat ground at normal crusing speeds I get enough variation so that my boost gage is fluctuating 1-2 psi. It is so noticable thet even my wife complained. (I do let her drive occasionally)
This occurs when not towing or with a 1300 lb boat trailer. Don't know what it will do when i hook up my 5th wheel as the engine is loaded a bit more.
Anybody else had this problem?
