Engine/Transmission (1998.5 - 2002) PCM wiring damaged
2nd Gen Non-Engine/Transmission 35 " tire help
2nd Gen Non-Engine/Transmission ABS light intermittent
A small animal has chewed through two PCM wires. They are on the left of three plugs. Light green / white stripe and white / red stripe. The truck seems to be running fine. Hopefully, these wires are not used on my 2500 ST. It doesn't have cruise control or power anything.
I'm looking in the service manual and the red/white is Fused B(+). The light green/white is Governor Pressure Sensor Signal, or A/C Select Input. Hope this helps.
I didn't think to try the A/C. That's the green/white. I'll try it this weekend. The other is a white/red stripe, not a red/white.
Wires repaired. The white/red stripe did control the A/C and it is again working. Thanks for the help.
