Hoping to not have to throw parts at my old truck, a 94 3500, thanks in advance for advice/ comments. The charging system has been hit or miss for a while, but a few days ago the speedometer and tachometer quit working. The abs light comes on and goes off like normal, but the wait to start and water in fuel light do not light. It is showing a discharge again as well. I've read the ess can be at fault, but there is no 8v power coming out of the pcm at pin 7 its labeled as a supply in the pinout. and the speedometer quit, thanks to the reading I've been doing I think its on its own circuit. I do have power at the pcm at pins 9 and 3. pins 11 and 12 are grounded. I am showing no voltage at pin 57, the asd relay feed either running or off. Have thought about jumping pin 57 to positive, but don't want to fry anything. I have cleaned the connectors that I can get at and examined for breaks in wiring, any thoughts? Thank you.
