Details here: TDR Privileges
I'm new to the TDR, and have a chance to pick up PDR HX35 off a newer 24 valve motor. Can I use this turbo on my 97 12 valve with little or no mods, I know the wastegate actuator bolts up in different spots, but will it fit? Thanks for any help.
I'm not sure which housing is on it. I would like the 14cm. Right now EGT's are not a problem with the stock turbo running 35+ psi. What type of boost will I get with the PDR?
