PDR intake kit
Another Speedometer Problem
Extended oil change on '93 with 5.9 Cummins
Unless you get a bigger turbo and do some thing about the small restrictive cross over tube theres no real point in a new intake manifold.
The reason it will not work is because the turbo inlet of a non-intercooled motor is much smaller than an intercooled one. It might be possible to make this work with an adapter hose from the tube to the turbo inlet.
The biggest gain would be to find a air to water cooler like found on the busses the same year or marine applications
