Details here: TDR Privileges
I am looking for the install instructions for the PDR HX-40 -HTB3 set. Also, how does one mount he 40 to the manifold with opposite threaded hole s and open holes?manifold flipped and spacer in between there are threaded holes that align and the other two are thru holes
you should have some studs--it's been awhile since I've had a 40, but I think you need to drill out the two threaded holes on the turbo so the studs from the HTT manifold can go through ----does that make sense---chris
