PE Box and ETH Question
accessing fuel test port
Dumb PF brake questions
Has anyone with an ETH installed the PE Box without an injector change? Just wondering if this will result in a moderate power increase and not create some problem. If not, should injectors be changed first (money will not allow changing both at once). Need some practical advice after finding out the VA box is not a great addition to an ETH. Thanks
Stan
2001 2500 SLT+ Quad Cab, 6 speed, ETH, 4X4, LWB, 3. 54 LSD Trailer Tow, Camper Special, 241HD, Tow Mirrors, Bright White, Line-X Bedliner, Putco Boss SS running boards, A. R. E. K Series Truck Cap, Reese Titan V Hitch, 2WD Low, DD 4" exhaust, BD exhaust brake, Isspro Boost and EGT gauges, Mag-Hytec rear cover with Amsoil Series 2000 75W-90 synthetic, Amsoil Dual-Remote Cummins Oil Filtration System (full-flow & by-pass); Practical Solutions Boost Module/Elbow; Amsoil 2 Stage Air Filter
ISB RAMBO, I have exactly what you are looking for as I have a stock ETH with 3. 54 gears and the standard PE with stock injectors. I think the power increase is great or at least for me as all I tow is a 6000 lbs. Jeep and trailer with no problems at all as I now can tow over the Rocky Mountains near Denver, CO at 60-70 MPH in only level 1. I would say do the box first or the injectors and then if you feel you need more do the other. I do feel that if you are towing the same weight that I am you may be better off going the injector route as it yeilds about the same power as level 1 on the PE.
2001 2500HD Quad Cab SLT SB 4x4, HO Cummins, 6-speed, 3. 55 gears, LSD, brightwhite/driftwood, air dam, 4w ABS, camper and trailer tow packages, fog lamps, CD/cassette, HD transfer case, snow plow prep, travel convenience group, cab lights, Isspro Boost and Pyrometer gauges mounted on A-pillar, PowerEdge, 4" JRE exhaust, BD exhaust brake. 12500 miles as of 7/26/00.
1980 CJ-5, Modified for off-road use, bobbed fenders, 350 TBI, NP435 trans, 4. 56 gears, Dana 300, Dana 44 front, Dana 60 reverse-cut rear axle, ARB air lockers front and rear, 15/35/15 Super Swamper TSL on 10X15 steel rims, Cobra CB, Warn 9000I winch, nerf bars, 1/4" steel rock crawler bumper front and rear, jerri can/spare tire rack, custom roll cage.
This is my firt post. I've been looking at a VA box, but now I'm not so sure. Does anyone have quarter mile times and EGT's with both the VA and PE? P. S. -My last truck was a '99 Powerstroke and my 2001 ETH is much stronger.
Douglas, thanks for the reply - that's exactly the feedback I'm looking for. My mind is now made up as to the best upgrade for my situation which is towing a 10,000# travel trailer. Since big brother maybe monitoring this site I'll not post it or place it in my signature. Thanks again!
Stan
