Installed the PE Comp box on a Stock '01 3500 Saturday and on Level 5 (Sub Level 5) his EGT's go through roof with only 20 psi boost. He removed turbo, drilled and pluged hardline hole and now EGT's are managable, but boost goes over 35 psi WOT no load (level 4, sub level 3). This thing will probably hit over 40 psi on level 5, but will this cause the HY35 to go to Lunch?
His next mod's will be Bill's TC as his stock one is getting torchered
Max
Max
