PE Comp vs. PE Pulse
Lift Pump Solution?
Bombed the TPS today!
What are the differences? Anybody out there care to share their thoughts? I am considering an upgrade from my EZ to one of these and injectors (DD1's or DD2's). I need some feedback before I dive in.
Thanks,
Otis.
get the COMP!!!!
To my understanding, the pulse is like an EZ in the power it adds, and is like the comp by the way you can control it from the cab. Think about the 3 jumper settings, you can switch from the inside insted of haveing to open the box, and manually do it.
Am I right yall?
Andrew
Give them a call.
I went through the same questions. I called Edge Products and after the differences were explained, it was an easy choice. The guy I talked to also seemed to steer me toward the Comp. The price difference was only about $50 to jump to the Comp. Hope this helps. BOMBS away!:D
