Whose done it??? diesel just hit $4. 60 in town, and i cant be doing that. im looking at getting a 100gal. in-bed steel rectangle tank, and use it for the peanut oil from fastfood joints.
here are some questions:
1. how is the peanut oil on the Injector pump, Injectors, etc? (will it gum them up over time, or cut down on their life span?)
2. How long should the motor be run on diesel before shut down, to fully prime everything?
3. how long should the motor be run on diesel after start up?
4. what type of filtration should be used for this stuff?
5. what type of pump?
6. how is it as far as power? loose any HP/TQ? will it roll coal like diesel will?
7. can it go bad? should i use additaves or somthing in it?
thanks guys i really apreciate any help. one of my best friends in NC, manages a Chik-fil-a right were ill be living, and he said he will give me all his peanut oil, so i cant turn that down. im just wondering how realistic a conversion is. with the warmer temps down in NC i figure it will be more fesable that up here in the VA hills, where the lows can dip down, even in the summer. thanks again
