Perform Service Display
Who fixes Uconnect radios?
Dome lights work, switches don’t.
TDEvans
HI, I got a 2012 One Ton Dually with 135,000 miles on her,I have a Perform Service message on the dashboard,I have done the depress the pedal three times like you do to clear oil change service,but that didnt clear it.Anybody got a idea why this popped up,what it is and how to clear it,Thx, for any reply's. Terry
Here is what I found.....
PERFORM SERVICE INDICATOR - RESET
RESET PERFORM SERVICE INDICATOR
1. Turn the ignition switch to the ON position, but do not start the engine.
2. Depress and release the brake pedal two times.
3. Fully depress and release the accelerator pedal slowly two times within 10 seconds.
4. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you start the engine, the Perform Service indicator did not reset. If necessary, repeat this procedure.
Thank you Timd32 that erased the message. Don't know why it came up. I have done CCV filter back at 68,000 miles,I know its getting close for a valve adjustment,Thx.again
ccv is a 67.5K miles service so you should have fired that service at 135.5K. Right on schedule.
The message pops every 67,500 miles, time to change it again.
And, on a 2012 non-DEF truck, it is also recommended to service the EGR valve at this time also.
Ok, thx guys I didnt realize we we were suppose to change that filter every 67,500.Will do that again.
