I recently installed an Autometer boost, and pyrometer gauge in a really cool steering column mount.
As per the instructions, I attempted to drill the manifold at the rearward port but was unable to because the A/C dryer canister was in the way and I could not get a straight shot at it. I had to place the probe in the front port instead.
Question; will this not work as well? What is the preference for placing the probe in the rearward exhaust manifold port? It seems to work fine.
As I pulled some steep grades going up I-5 with a 10k trailer, still on legal fuel, I was pulling a grade in 6th. When the rpms dropped to 1800, I down shifted to 5th and mashed it. Boost bounced to 35 for a second, then settled at 30 and held steady. RPMs dropping slowly in 5th, EGT stays at about 1350 from 2500 rpm down to 1800. I down shift to 4th, rpm goes to the governor, and stays there, EGT rises to 1450. Water temp increased from 195 to about 205, but settled back after I crested each hill. I only kept it at 1450 for 30 to 45 seconds on 3 occasions. Letting up slightly sent the temps down to between 1300 to 1350 fast.
Only having experience with an old 335 Cummins in a '64 Kenworth, I thought that as you relieved the strain on the motor by shifting down-the motor running freer at a higher RPM, the EGT was supposed to drop??? I just thought the rise in EGT after I down shifted was counter to what I expected.
Don't get me wrong, this truck is a pullin SOB, and I have no complaints about its performance. It would climb a tree if you asked it to.
I think the pyrometer is reading hotter than it actually is because when it's cold out, and the motor is stone cold the gauge will read about 95 on it's scale after I have switched the power on but not yet started. Also, after idling for 3 to 5 min the EGT won't drop below 350, you could idle it until Christmas and it'll be at 350. This has to be balanced against the probe located in the forward most port on my truck where the temps in the exhaust stream may not be as hot.
Are the temps OK for the conditions I stated above?
Thanks, M.
Thanks, M.
