Well I am having a performance issue I hope you all can help me with, I just today installed a reman VP-44 due to the fact that the old one was cutting out when cool in the mornings and sometimes during the day also was bucking at times, anyway with the new one it seems sometimes it is low on power, pedal to the floor and boost wont rise fast almost like it is not being fueled enough. When I reconnected the batteries after the VP install i fully depressed the pedal three times then attempted to start with no luck due to the need for bleeding the fuel system. So anyone have any ideas, I do not have a diagnostic connector hooked up yet so I cant pull codes (if any) I also used the keyway that came installed on the pump from www.cumminstuff.com
Thanks , I hope it is something cheap and simple (BTW fuel pressure at steady 14 at idle and doesnt change much under load 1-3psi change) All of this is with comp box off.
