Engine/Transmission (1998.5 - 2002) Permanent antifreeze shelf life
Engine/Transmission (1998.5 - 2002) Stratapore fuel filter/pump
2nd Gen Non-Engine/Transmission LSD Problems
Does anyone know if there is a shelf life for new antifreeze stored in factory sealed containers? I have figured out that I have nearly 20 gallons that I have had for probably 15 years.
It looks brignt and clean and smells just like it should, but I wonder if you have seen anything published regarding other chemical components that could fail in extended storage.
I'll bet the fluid is ok but the technology is ancient. There has been a tremendous improvement in coolants and oils in the last 5 years let alone 15
That is interesting... . I have a lot of old motor oil, too, I realize. Not anything suitable for my Cummins, however.
I wonder what sort of improvements there have been in coolants, do you know more about that?
thank you...
i agree that chances are the coolant is probably in fairly good condition but the changes antifreeze has went through through the years has been tremendous. as far as oil goes, you can start to see settling of the additive's after long term storage. :confused:
When I was doing my homework for the anti-freeze update I sent in to the magazine I think that I saw somewhere that the old-type anti-freeze did have a shelf life. I'm not positive, but I think I read somewhere that one of the advantages to the new organic acid technology (OAT) anti-freezes is that the OAT anti-freeze has a much longer shelf life. The numbers that stick in my mind are about five years for the old-style anti-freeze and 15-20 year shelf life for the OAT stuff.
I'm not willing to do the Internet searching to verify that, but the Valvoline site may lead you to some information on the subject. You can also call or e-mail their technical people with that question.
That said, I agree with the previous comments on improvements to anti-freeze. I don't know how much you mind changing your coolant, but I consider it to be a major nusiance at best. I have installed an extended-life anti-freeze. It's an OAT type and can be renewed by merely adding a pint of extender fluid. It will go three years or 300,000 miles before requiring the extender. Then it can go another three years.
There are several brands of extended-life anti-freeze available, but the only brand that I could find extender for was Caterpillar.
Data:
Caterpillar Extended Life Antifreeze/Coolant (concentrate): 119-5150
Caterpillar Extended Life Antifreeze/Coolant (pre-mixed): 101-2844
Caterpillar Extender for above Antifreeze: 119-5152
I used the pre-mixed. If you use concentrated OAT anti-freeze (anybody's brand) DO NOT USE TAP (CHLORINATED) WATER.
Loren
