Permatex #2 for pyro install ?????
Comp Question
big grill guard
I've done a bunch of searches on pyro install for my EGT gauge and can't seem to get an answer to this question.
I see a lot of guys are using an anti-seize when installing the probe into the manifold. I don't have the tube with me, can I use Permatex #2 for this application? I don't know if it is rated for the kind of heat that it will see in this location and I need to know if I should run over to NAPA before heading home for install.
Can I use the Permatex #2 for the probe install or should I get an anti-seize for this? TIA.
zman
ZMAN
Get some anti-sieze, reason is that exhaust bolts are famous for getting stuck in there, the anti will insure that you will be able to remove the probe at a later date if it fails..... Kevin
I agree with Kevin, anit-seize would be the best for this application. Permatex #2 is good stuff, but I believe the temps. would be a bit high for it's use.
Scott W.
You can get anti-sieze at Autozone or any other auto parts. I used it exhaust manifold bolts, turbo bolts, and anywhere there is high heat.
Charles
The pyro was put in my truck without antisieze and I just about ruined it when I removed it to change the manifold. Cleaned it up and used antisieze for the install. Had it out again since then no problem.
Anti-seize is the only thing that will work with the high temps.
Thomas, now you have me wondering what happens below minus 20.
Thanks for the input, guys. Had no doubt you'd help me out!
Off to NAPA.
I should be getting my own parking space there soon.....
