Engine/Transmission (1994 - 1998) Phat Shaft 62 Turbo
I have a Phat Shaft 62 turbo sitting around in my garage that came off my '03before I put twins on that truck. Does anyone know if this turbo will work on my '95? If not I need to sell it
Chris
they are common rail specific. it could be made to work, but the wastegate system and flange are probably different, the water lines are different. depends on how far you are willing to go.
Should work fine. Flange should be the same but you will need a 4" down pipe and reclock the compressor.
The big question is will your current setup spool it quick enough without blotting the sun out.
