Photo Test
3g power
2003 Truck Question
I got this from TDR, I was having the same problem. "The file size limit is 122,800. This is a pretty good size file at 72 dpi resolution. " I was trying to put too large a file in. I just reduced the size and had no problems. Hope this helps.
Dean
Must have Dean; if you can see it! Trouble is, I don't know what I did; I tried so many things; don't know which one worked!
Task
Dean Upson told me to keep the file under 32,000 Bytes, whatever the h--- that means? I tried that, but when I would do the "preview reply" at the bottome of this page, it wouldn't show me anything. So, I just did the "submit reply" anyhow; & low & behold! Doubt I'll ever be able to do it again; but you try it!
JD
DAMN
So, when you right click on your photo, under "properties," does it show you the size in Bytes or KB's? If it's more than 32k bytes, it won't go; you'll have to go to the "image" & re-size it down. Don't know what else? Keep trying; I wasted all day; you might just as well waste it, too!
You need a photo editor that can compress the image. It's usually under the "Save As" options in most tools. Also reduce the size of the image to 800x600 or less.
Theonly way I could get one on herewas to change it to a gif I don't know what differedce that makes, but it worked for me.
Fireman
Boy Dave, now that's what I call a good lookin outfit! When she's thawed out a little around here, I'll post one w/the Ranger. I'm thinking it will look pretty good; the boat's that dark blue/ with lighter metal flake & pins, & the trailer & cover are black, so they oughta go good w/the black beast.
4xquadrod - Lookin good! If it weren't for those fancy wheels & all the sand, I'd think you came up to Oregon & stole my truck!
