Pic of a Door badge
Gauge Location
Should I or shouldn't I have the rotors turned??
Your don't wanna picture of that nasty ol 24 valve door badge. :D:D
Here's the door badge of a properly valved truck, you know, like the one you have;) :D
gitchesum , The reason I didn't use mine door plate was it was more worn than your almost all my letters have blacken areas.
Thanks all!!!
:D
Weeellll If I have tooo
Awww alll Right Here's another way to go as well[#ad
<BR>/COLOR]
<hr>
Truck Bio:
Y2K+1 3500 4X4 Quad Cab 4:10:1 LSD
Powerpack By Bank's (4 inch exhaust,High ram intake,wastgate mod to 38 psi,ottomind TLC +guages,K&N) ,DTT~93%TC~&~VB~TC Smart controller, Mag-Hytec's Double Deep Trans pan,DD injectors+Van Aken+Autometer Guages. ,Piers Modified PDR HX turbo,Enterprise Engine PerformancePusher pump setup Front End Leveling Kit from Jakit with 255/85R16 BFG http://www.bfgoodrichtires.com/ M/T's Custom Rhino Liner (see Tool Man's truck feature)DeeZee Black Diamond Plate Bed Rails And Tool Box , WAAG Side tubes with kick~outs Mopar Performance accessories-Sill plates-hitch cover-cargo aux lamp'n'Power, Hadley air systems 150 psi comp and air storage. DynaMat Sound deadening applied to entire cab and doors, Check out Tool's Stuff#ad
N. E. T. D. P
