I am wonder if anyone on here has any ideas of things to check first. This morning I was driving down the road, everything was going just fine, and then all the sudden my accelerator was dead, so I tryed the cruise quick and nothing there either. By this time I was slowed down and stepped in the clutch to down shift and the tach went to zero, when I let the clutch back out the tach went back up just like it normally should. It seems I am not getting any fuel. Tryed starting and nothing. All this happened with out any warning lights all gauges read fine, no bells went off and there isn't any codes if you check on the odometer display, when I got my pickup hauled home I borrowed a buddies BullyDog and plugged it in and it also did not read any codes. It was very cold outside so I only checked the important fuses. I also unplugged the Quadzillla I was running from the engine sensors. Tomarrow I will do some more investigating, thought I would check and see if anyone has seen this before. Maybe the FCA, or something in the CP3? I am assuming that if it was a crank or cam shaft position sensor I would have gotten a code. or any other sensor for that matter. TIA
