The Drill Jig To Neutralize The Killer Dowel
This is the way I did it. If you find a better way to use it, let us know.
Loosen the fan (1 7/16” wrench, L. H. THD) and remove the radiator overflow bottle. If you can get the fan out past the shroud, do it now. It will save you time. If not, continue with the following: Release the windshield washer bottle on the driver’s side. Unbolt the radiator shroud. Push the top of the shroud towards the motor and pull the fan out between that and the radiator. Move the shroud from side to side to sneak the protruding ears past the radiator hoses. To help with this, bend the top center of the shroud toward the motor-this makes the shroud a little narrower.
Now remove the serpentine belt. Remove the two bolts that hold the alternator on. The bottom rear nut is 15mm, the front bolt is 13mm. Without disconnecting any of the wires, set the alternator up on the rubber intake hose. Remove the 6 bolts that hold the fan pulley on and then the 4 that hold the fan mount to the block.
Put a shop towel over the top of the bottom pulley, then clean the area to the right of where the fan mount was located. (That’s the area where you are going to be drilling. )
Remove the 2 bolts from the front cover, put the drill jig on and replace the bolts. Go underneath the truck and hook the regulator to the breather hose. Set the regulator to a maximum of 2 lbs.
Using a low-powered drill-such as a cordless-put the smaller of the two bushings in the jig and drill through the casting with the drill provided. The aluminum casting where you are going to be drilling is approximately ½” thick. The stop on the drill is set at 1”. (When you go through the aluminum, if the drill does not go freely to the stop, then you MUST remove the cover because your dowel is already part way out. With the cover off you can drive the dowel back into the block and then continue with c-sinking and tapping. ) Once you have this hole through you can increase the flow on the regulator several more pounds to help clear the chips.
Alternative Methods
1. If you do not have a pressure regulator, but have an air supply, you can do the following: Get a long piece of rope (clothes line), wrap a paper towel around one end and with a screwdriver force it into the breather pipe. Tie the other end to your steering wheel. Remove your oil filler cap, wrap a shop towel around the end of your air nozzle and hold it against the filler hole. Blow only enough air into the motor to equal about two pounds pressure. (Keep the shop towel loose enough so you will not create a dangerous amount of pressure if you get carried away. )
2. If you do not have any air supply, you can do it this way. Drill only a ¼” to 3/8” deep in the casting. C-sink the partially drilled hole. Fill the drill with light grease and drill the hole the rest of the way through. Clean the hole out, fill the tap with grease and tap the hole. If you have a way to rotate the motor by hand, (by turning the balancer, etc. ) do it between drilling and tapping so any chips that do fall on the gears inside are not all in one spot. A few stray chips spread out inside will not hurt anything. ,
Pictures of the Drill Jig
Alternative Methods
