There are no holes drilled in my dash to mount this. I used the forward dash to firewall bolt at the base of the windshield to mount the rear of the unit. I used a piece of vinyl from the cross brace under the unit to mount the front of the unit. I used the same factory vinyl that is used on the center console lid and it's the same stuff I used to cover my as yet uncompleted center console. It doesn't move around at all, and doesn't obstruct my vision. The only problem is that I can't hear the speaker that well. The piece of vinly I used to mount the front pretty much seals off the bottom of the unit and doesn't let much clear sound out. I plan on mounting an external speaker under the dash in the next week or so.
BTW, I can also pull the CB out and disconnect it easily If I have parked the truck in a bad area. It just slides out of the mount.
Just another option for mounting your CB's.
