picture posting is easy if you have the images uploaded on a site/server that allows for direct access to it. to do that all you need to do is the following. .
in the below, replace all the () with [] to make it work
type in the image tag (img) then the address where the image is located. i will use this. .
then close the image tag by typing in (/img)
that's how i do it when i attach directally.
there is the option of having the forum software do the work for you. if you click on the IMG button in the vB code section, it will ask you to type in the images location on the web. when you do that, it will create the approprate tags to make the image work.
most of the time though, because most of the images i take are big and i don't want to tax the dial up guys, i post them in a photo hosting server. there are many of them out there. picturetrail, yahoo briefcase and webshots are some that are avalable. i personally like the webshots one the best.
M Barnett
your compressor looks kinda like mine. what size is it? mine is a 60g/5. 5hp pretty much overkill for home use eh?
