My 2000 with the original lift pump recently died at 80k. I took the pump apart to see what caused it to fail. This is what I found...
I had lift pump that produced 7 psi when you turn the key on and drops to 0 after the motor starts. Toady I took the top cover off my lift pump. I saw the 4 blades of the vane pump. I can not find any defects with the vanes or the housing that the vanes spin in. I pressure checked the relief valve and it opens at 12psi, so that was not the problem. The brushes had lots of life left in the but the center portion of the electric motor, the part where the brushes ride, was very worn. I wished I had a way to fire up the electric motor and do an rpm, current, and voltage test, but I do not have the tools to do so. It looks like in my situation the motor portion of the lift pump has failed and not the pump portion. My question is, could this problem be caused by low voltage or vibration??? Does the pusher pump / larger fuel line ease the load on the motor thus making it last longer???
I had to trim the pics down to be able to post them on this site. If anyone want the high quality originals, just email me.
This is a picture of the lift pump with the cover removed. You can see the 4 vane rotor pump.
