Piers thanks !!
Blown Gear Vendor overdrive
Remotebracket Dual Filter Mount
Piers, thanks for the help with the gov. springs and injectors. got them in and whopeee!!:D :D man that woke it up. got to watch egt's peged my 1600 gauge on test run. it's fun to play with the smoke hehe!! again THANKS. mike
Piers is one Heck of a great guy
After all the time he spent helping me get my governer spring kit and pump adjusted right. I don't know where he get all his time.
May be the clocks run slower up north LOL
ThanKs, Piers
And his competitve pricing certainly doesn't take you to the <em><b>Bank</b></em>?
I've witnessed the wizardry of Piers first hand.
-John
ditto the above kudos!
Piers you better get that turbo ready for me!
PS: If I somehow get stuck buying Bill dinner (even though I won the bet), would you and Louise want to join all of us? :)
Hi John,
Thanks, Louise & I would love to join you guys for dinner. But I really think Bill K. should pay, as he did LOOSE THE BET:D
Piers Turbo + DDIII's = *Grin*
Thanks Piers.
Only "issue" I have is a heater line thats right next to (at times rubbing) on the exhaust housing, due to the braket that was made for the ATS manifold, gonna have to fix that I don't like the heater line in that location (heat and chaffing). Other then that it runs pretty good..... no less lasg then my HY35 had (as far as I can tell). Dirty "stock" airfilter = 30psi boost.
transmission will be done next week and then the COMP goes on.
Re: Piers Turbo + DDIII's = *Grin*
Originally posted by KatDiesel
Thanks Piers.
Only "issue" I have is a heater line thats right next to (at times rubbing) on the exhaust housing, due to the bracket that was made for the ATS manifold, gonna have to fix that I don't like the heater line in that location
I fabricated my own billet aluminum heater hose bracket and altered the OE steel heater hose standoff to clear the rear joint on my ATS exhaust manifold. My custom aluminum bracket mounts to the threaded casting boss on the ATS manifold. BTW, bracket modification was not mentioned in the ATS installation instructions. :rolleyes:
