Pillar Gauge Mount-What Paint for Grey Interior?
contacting DC
Correcting speedometer
I just ordered the pillar gauge mount and pyro and boost gauges. I guess the plastic will be black. Has anyone found a good spray paint to match the interior grey?
Thanks in Advance
Mopar did offer it. I'm not sure if they still do. Also, there are two different shades of grey DC uses. Mist grey(light) and Agate grey(dark).
I could not find any ready made paint from Chrysler in my area. I went ot the local auto paint provider and they looked up the code for "Agate". It is,
PPG brand UCV 9856
They mixed up one pint and I had a friend put it on with a air brush. Looks factory.
Good luck.
2000 3500QC 4x4, 6-speed, 3. 54, Patriot Blue, SLT+, every option, VA, 275's, Mopar brushed aluminum side rails,
Mopar $$$ tow hooks that should be standard.
Turbo... I had a local dealer order a can and to my dismay, its was the worst match i had ever seen,What a waste of 8 bucks. Having used the Dupont dye before on my mustang to change the whole interior to black,I purchased it and the final product is as close as you can get. Only thing , you have to have access to spray equiptment but its worth it... JB
99 Quad,Long bed,4x4, SLT,Auto,K&N,Mobil Super Delvac 1300,fuel line up-grade from lift pump to filter and from filter to injection pump, Suncoast coverter,BD valve body and pressure-loc,Mag-Hytec trans pan,Amsoil ATF-4,Auto meter Ultra lite gauges:Boost,EGT,Fuel Pressure,Trans Temp, "true" Jet-Hot Coated 5 inch exhaust from turbo to tail pipe(over the axle)Borla shoot-out muffler,DD stage 3 injectors and boost module,HX-40 16cm in transit..... finally a blue box or TST box or?????
I just purchased some paint from the dealer. The match was good. They have to look up the color code for your truck, there are alot of different grays.
Paul A. Schmidt
95, 4X4, SLT 2500, 5 spd. , 4. 10, 270 hp. ,675ft. lb. TST, AFC spring kit,215hp. injectors, Pacbrake, Walker muffler,
GearVendor O. D.
Eastern PA.
I got a can of interior Slate blue paint from the dealer. What a great match. Almost perfect.
Bill R
94 2500 SLT,4X4,5 Speed,3. 54 LSD... . Still looks brand new... .
That gives me some options to think about.
Thanks!
99 3500 Reg Cab, Red, 2wd, 5spd, 4:10
(2) 87 GN's (Also turbo 6's)
went to my local dealer, they ordered me a spray can,,,almost perfect match !!!!
'95 xt cab,slt,4. 10,auto,265 stones,K&N,tst 605, silencer ring in top of toolbox, boost and pyro in full pillar mt. 153,000 mi and climbing... went to feed the cat and it was GONE !!!!!
