Pillar gauges needed?
info needed to put 6.7 air cleaner on 2007, 5.9
What's needed
So I would like some suggestions and thoughts on what you guys think about this idea. I have a 2006 2500 4x4 with about 155K. I have an edge juice programmer on it, for those with out an edge- I'm able to monitor 4 items at a time. Right now I currently have it set up where I am monitoring the EGT, Boost %, Load %, and the Engine temp. I'm satisfied with the set up but would like to be able to monitor more and everything a little better, a big one being the transmission temp. I've been looking into getting a 3 pod set up for the pillar. I would be able to monitor some things on the pods and change the setup on the edge to monitor other items. One of the big questions I have is if I take the EGT sensor off of the edge can I plug it into a pod gauge or would I have to run a second EGT sensor line to the exhaust manifold? I would like ya'lls thoughts on how to do the setup and move things around or what kind of setup you may have? I'm ready to pull the trigger on a new setup but want to go about it the best route. Thanks for the help...
