Engine/Transmission (1998.5 - 2002) pinion bearing bad?
If this bearing is bad there will be evident play at the yoke, correct? If not, i'm wondering what else I can look for to target the bearing being bad.
There may not always be play. If the bearing surface is brinelled, it will make a bunch of noise, but there may not be any play. If the races are scored, there may not bea play. What makes you suspect a bad pinion bearing?
I've got a sloppy clunk when I take off from a stop. Or gass it in reverse. My whole housing is moving making it feel like play in my ring and pinion. I thought that maybe if my pinion was out and "crawling" up the ring rear maybe the angle was pulling the rear end up and down. I think this started when I had my plow on overnight and had to plow in low range due to deep snow. All that back and forth stress must have broke/wore something out. Just can't find it.
It doesn't leak oil, but it wines a little around 30mph. I've also got alot of vibration around 75. Which is nothing new. Ujoints are good.
what helped me troubleshoot my bad pinion bearing (besides the low growl at all speeds) was to jack up the rear end--support it with jack stands--then put it in drive. i was able to use my creeper to get close to the diff and listen. hope this helps...
chris
