pinion factor for speedo
Psycotty Air
Fast Idle Question
:confused: I went from 245/75-16 tires to 265/75-16 tires my transfer case has no speed sensor or gear for the speedo i believe the pcm/ abs system reads the rear axle ring gear sensor. I know at work i can set the pinion factor for different size tires on the mini vans but not on my truck. i use the snap on mt2500 scanner, any one know of a tool or a how to: with out going to the dealer for thier scanner?
