PINION SEAL
wiring harness
smokin'?
MY NEW PINION SEAL, NATIONAL #9316 IS LEAKING. DOES ANYONE HAVE ANY INFO ON A DOUBLE LIP SEAL SIMILAR TO THE C/R AXLE SEALS THAT I HAVE READ ABOUT ON OTHER POSTS? THE AXLE HAS AMSOIL IN IT[IT LEAKED WITH CONVENTIONAL LUBE ALSO] AND THE VENT IS NOT PLUGGED. THANKS.
93 W-350, 4x4, 4. 10's,2 1/2 skyjacker front springs,255/85/16 wild countrys. K&N filter,muffler removed,16cm turbo housing, auto meter guages.
OK, I'LL ANSWER MY OWN POST. WENT TO THE PARTS STORE AND GOT THEM TO LET ME LOOK IN THE SEAL CATALOG. FOUND A NEAT REPAIR SLEEVE SIMILAR TO WHATS USED ON HARMONIC BALANCERS. SORT OF PRICEY AT $30 BUT BETTER THAN A LEAK. SO FAR NO LEAKS AFTER 300+ MILES.
