Engine/Transmission (1994 - 1998) Piston cooling nozzle question on rebuild
Engine/Transmission (1994 - 1998) Lift Pump Cam Plunger length
Engine/Transmission (1994 - 1998) Generator Light
Hello, I'm rebuilding my cummins for my truck, and i'm using an 89 block, and 95 style pistons for the inline pump. Now my question is that in my gasket set I have two different style of cooling nozzles, so which one do I use? the ones that came out of the block were the short clear ones, but that was also for the rotary pump. I didnt know if it made a difference on the block, or the pistons on which one. The longer ones also have a bigger id with them. I would pull my other engine apart to check which one it has, but I buried it in the barn already and it would be a half days work to just get it out. Thanks, Steve
Hmm??? everyone I talked to that has replaced them always use the ones that came out of that block, but no one has ever used an older block with newer pistons... Well I put the green ones in because thats what my old block had in it, and i'm also using the oil pump off of that block too, so I guess I'll see how it goes...
