While repairing a dented oil pan on my truck, I found two piston cooling oil nozzles sitting in the bottom of the drain pan. I could not determine if the ends of the nozzles that fit into the block were cracked (part still in the block), or if the nozzles were still in one piece. I purchased the truck with 120k and it currently has 132k. I generally drive at 5,000 to 8,000 feet, and my EGTs seem pretty high for my level of fuel. I have hit 1400 pre turbo with an empty truck once while not paying adequate attention to the gauge. I have a few questions. First, are the nozzles pressed into the block, or do they use some other form of anchoring? Is it possible to replace the nozzles with the engine in the truck, dropping the oil pan was no problem. How long are the nozzles? With two nozzles missing, I would think that oil is still spraying up to the back side of the piston, but there would actually be more oil flowing, as long as the oil pressure remained close to the same as when the nozzles were in place. My oil pressure seems about normal. Could the lack of the two nozzles be causing my EGTs to be above normal, or are my EGTs normal for the elevations that I drive? Any help or suggestions would be greatly appreciated.
