Hi Guys,
I'm rebuilding a '95 and I've also got some new piston pin bushings for it. My problem now is that the inside diameter of these bushings is way smaller then the pins outside diameter.
The pin is 40 mm (1. 575") and the bushing is 39. 6 mm (1. 56). I already put a few bushings in the rod, and it really looks like there's no way the pin is going to fit through there. Shouldn't it be sort of a 'loose' fit, so the pin can move/rotate in the bushing?? What's the normal way of mounting these bushings??
Thanks in advance!
Cheers,
Daan
Thanks in advance!
Cheers,
Daan
