I put my fuel pressure gauge in on Saturday and low and behold my FP was 8 psi at idle and I could drag it all the way down to 0 at WOT
. I called Napa this morning and they wanted 195. 00 for the pump. So then I called the Freightliner dealer and they told me they would sell it to me for 130. 00 and I could pick it up at Cummins. So I did that.
I got home tonight and started to put it in. I took loose the fuel filter and moved it out of the way then went to take the mounting nuts off the lift pump one came off and the other two just spun the studs out of the lift pump.
Now I don't have to tell you its not very roomy down there but it was a PITA to hold an open end wrench and the socket with one hand and get those nuts off. Well I got the old one off finally and the new one back on but then managed to drop the inner sealing washer off the back bango not once but twice into the dirt
By now it was completely dark and I found my self crawling around in the dirt with a 500 watt halogen light looking for the washer as one of the of the mounting nuts. Now its starting to get cold (well cold to me) low 40's I find the sealing washers both times but the nut is long gone. I finish up after finding a nut and hop in the truck and bump the starter and wait to hear the new lift pump fire up. Well thats right I hear nothing. This worked every time with the old pump. I go back under the hood and make shure all the electrical connections are snapped together tightely and they are. I try to test for voltage with my test light but can get nothing. I even unhooked the new pump and pluged the the old pump in to see if that would work and It still would not fire up. By the way once that wiring harness is clipped together it's a mother to get apart with one hand.
I even went as far as to switch the relay out for the lift pump.
And of course the little lady was expectiing us to go christmas shopping tonight and keeps reminding me that this is taking to long. :-laf
By now I am a little more than frustrated and decide to go in and get another beer and think about the situation. After I finshed my beer I decided to try and start the truck. To my suprise after about 30 sec of cranking it fired right up and FP was a steady 16 psi.
I dont know why the lift pump would not cycle on before i'll have to check it tomarow but it seems to work good while driving. I can still pull my FP down to 8 psi so I think some bigger fuel lines are in order.
Sorry for the long post just venting a little #@$%!
Thanks
Thanks
