I put a retaining wall using 18" retaining wall block that is 140 ft starting at 18 inches and going up to 6 ft tall in the middle. My neighbor is a contractor with the local brick yard and he told me exactly what to do. I laid about 4 rows of block the entire length of the wall and then lined the back of the wall with typar which is fabric for use under gravel roads to keep the gravel from disappearing into the ground. The fabric was cut to four feet. After lining the back of the wall, I placed a 4 inch drain line which was wrapped in fabric to keep anything other than water from entering the line. I then backfilled the wall with 57 river rock. I then flipped the fabric back over the gravel and continued to build my wall up another 2 feet. At that point, I pulled the fabric back to the backside of the wall and backfilled again. Anything over four feet needs to geo grid to tie the wall back into the backfill to keep the wall stable. To do this, I laid the fabric on top of the existing rows of block extending straight back over the river rock backfill until it met the existing earth. I then continued to lay the block up to the finished height. The block will hold the fabric in place and then backfill over top of the fabric to the top of the wall.
The wall has not moved an inch and nothing comes through the wall. This was a lot of work, but I know I did not take any short cuts and if it should happen to fail at some point, I know it wasn't because I did something to save a dollar or a bead of sweat.
My wall consisted of 28 pallets of block and I used a total of 74 ton of river rock to backfill. Luckily, my neighbor had a bobcat that he would bring over to backfill the wall as I went. Just in case you didn't know, the walls are prone falling backwards if you build them too tall without backfilling every couple feet as you build them. You also want to put the first row of the wall under grade to act as a toe hold for the bottom of the wall.
Sorry for being so windy, but hey, that's the beauty of this site. To hear other people's experience. Right?
