I caught a little of that thread too. Maybe there was a bad batch of nozzles made, but would really look more into the failure. The temp those things see should never be high enough to "fatigue" the plastic. Furthermore, they're not a moving or wearing part, and the lubrricant they pass shouldn't be erroding the nozzle. When molecules pass each other, there is friction, so maybe they would errode or wear after tens of thousands of hours of use, but a mid-range diesel usualy doesn't hit 10000 hrs(around 300k miles, depending on application), almost never 20k hrs.
Yes, loosing oil nozzles is a very bad situation, It has happend to me. It wasn't the nozzles fault in my case.
With millions of happy engines on and off the road with plastic cooling nozzles, there could be hundreds of failures evry year that
may be the nozzles fault, but the percent failure rate is still not enough for me to condemn an engine based on material of cooling nozzle.
Case in point: Hundreds if not thousands of turbochargers are trashed every year because the pyro probe broke off and hit the impeller. Compare that to the uncoprehensible number of turbo diesel engines sitting in the country right now that have not had that problem, most dont even consider the problem. Poll the TDR alone and see nearly evry one here puts the probe in the manifold.
If there is a reason not to buy an ISB Cummins, its the VP44 and/or Carter lift pump.
THAT'S a failure rate to be upset about!
