Plastic trim's coming loose
Truck links - Useful
Used 1993 Lynnwood Dodge
The trim around the wheel wells and along the doors is starting to come loose in a couple of areas. It's about 2" wide. Is this just installed with pressure sensitive tape or is it glued on? Do I need to remove and clean or can I just resecure the loose areas?
Anyone know?
Side Trim
The short length of trim under the Fuel filler door came off of mine.
Went to Napa store and bought some trim adhesive and replaced it. No problem since.
Walt;)
. . on my '92 the trim around the rear wheel wells had two spots where the trim slid over a protrusion, much like the head of a bolt, that was attached to the sheet metal. That and adhesive tape held the trim on.
gary
