be careful when moving it forward, if the gov. lever is not adjusted correctly to u moving it, the throttle spoon can get stuck under the plate. I think that a hair back from forward is about as far as u want to go. We could really go on for days about where to but it. What Piers has told me in discussions over plate possision, is that it should be a little infront of middle to 3/4 or so. He mentioned Faster HP. Piers says 18 mm of rack travel, some others say 21. As a general rule of thumb i position it an 1/8 to a 1/16" past middle for mild increases and an 1/8 " from full forward on full power hp increases. But when moving the plate from forward to back check Gov. Lever posision. After looking at pumps and seeing how they work, i would think that Gov. Lever adjustment could increase or decrease fuel when the spoon hits the plate. This can go into a whole discussion. To check Gov. Lever adj. go to Piers' website and go to technical, its all listed there, good luck in making that CTD move out! Reb
